 Help! Tuyau du carburateur?
Sova
Bélier Buffle
Nombre de messages : 36
MessageSujet: Help! Tuyau du carburateur?   Ven 10 Mai - 19:25
Hello
Im speaking only english...
Please what is this tube from carburettor and where has been connect?
I dont have connect this tube from beyond
sorry for my english...im from Czech republic, renault 11 turbo owner
hello to France!
MessageSujet: Re: Help! Tuyau du carburateur?   Sam 11 Mai - 16:51
Hi Sova,
Could you take a wide picture please ?
I don't see where is situated your tube.
What's your engine ?
Do you have air conditioning?
Sova
Bélier Buffle
MessageSujet: Re: Help! Tuyau du carburateur?   Sam 11 Mai - 21:59
Hello
It´s C1J 760
Here is wide photo...i dont know where connect this tube...:-/
Thats Renault 11...28 years old...this car dont have air conditioning.
Thank you
Fred6359
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 8:34
c pas le tuyau de depression qui va sur l'aei sa??
Fred6359
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 8:38
si si c bien sa c le tuyau que va sur le boitier électronique d'allumage (petite capsule noir)
Sova
Bélier Buffle
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 11:40
sorry but i dont know french...and google translate is very poor for french-czech translation
Both languages are difficult in sentences composition...
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 14:09
It's strange! With my docs, for engine C1J 760, your tube must be connected on the turbo's wastegate. But, on your picture you have a another tube already connected on the wastegate. scratch
Have you changed something before?
As Fred says, your tube may be connected on the AEI's vacuum unit.
Have you some problems with your turbocharger (pressure/ triggering) ?
Sova
Bélier Buffle
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 15:35
I dont think so...All is Ok with turbocharger pressure
I forgot said...car, engine running fine...i think...
Only i was surprised, those tube doesnt connect nowhere confused
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 16:06
Have you a tube connected on the vaccum unit (AEI) ?
Sova
Bélier Buffle
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 16:28
Embarassed
Sorry but i dont know what is it confused
I've never heard about it before (AEI)
What that a where I find this?
I thought you talked about climatisation...
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 16:45
Oh sorry, AEI it's french... that's means "Allumage Électronique Intégral".
On this picture you can see the "AEI" on my car.
The tube is connect to the small nozzle (broken on this picture).
Ok for you now ? Do you have a tube connected here ?
Sova
Bélier Buffle
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 16:50
Oh..i understand now!
In english its probably called "Ignition Module"
Yes i have connect that tube, which u showing me here...
This is other tube about I talking scratch
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 17:02
Yep, ignition module in english.
So the tube connected here, where he went?
Sova
Bélier Buffle
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 17:54
yes, tube is connected on the vaccum unit...
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 18:01
Hello, this is not your overflow tube is a tube that is connected to nothing and placed above the gearbox ..
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 18:05
Du coup son branchement de la wastegate est bon alors ?
Et il sert a quoi ce tuyau ? Mise à l'air libre ?
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 18:17
Sa wastegate est ok, c'est en cas où il y a une trop grosse arrivée d'essence, le trop part par là.. Very Happy
Sova
Bélier Buffle
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 18:20
oh im surprising how simply thats it... Shocked
so...simply this tube is not connected for nothing?
very surprising and very funny solved problem Very Happy
Very Thanks friends from France!
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 18:32
Nothing, but do not let the tip above a heat source because if gas release, the fire insured ..
Place the tip over the box .. Very Happy
Sova
Bélier Buffle
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 18:44
Ok, Very thanks for your suggestion
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 18:54
Y're welcome ! Very Happy
Par contre Guigui, pourquoi sur mes docs il branche ce tuyau sur la wastegate ? Shocked
Grosse difference entre le C1J 760 et C1J 770, sur le 770 la wastegate est a double effet.
De même les refs des carbu entre ces 2 moteurs sont différentes. scratch
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 19:14
Car tu as deux montages entre phase 1 et 2.. Very Happy
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 19:20
Ça je m'en doute bien, sur le 760 on voit bien sur le schéma que le tuyau commande la wastegate.
Bref je connais pas assez bien la version turbal, jvais finir par en chopper une rien que pour me former Twisted Evil
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 19:24
Bonne idée.. lol!
Fred6359
MessageSujet: Re: Help! Tuyau du carburateur?   Dim 12 Mai - 20:04
et en resumé pour ma pomme vous racontez quoi?
